Done that and get this
Vehicle Details
Vehicle Details
The summary vehicle description is supplied by the DVLA
for registration number DU01NLT
No descriptive data is held by DVLA for registration number DU01NLT.
If the registration is correct, continue with the check.
VEHICLE ENQUIRY Services Provided By DVLA: DVLA
Vehicle details could not be found
As it has not been possible to locate the vehicle details, your enquiry cannot proceed and has been cancelled.
If you want to check the vehicle record held by DVLA...
Ok. Try this.
You can use the Vehicle Enquiry service to check what information DVLA holds on its database about a vehicle.
In order to make an enquiry you will need the Vehicle Registration Mark (number plate), and the Vehicle Make
http://www.vehiclelicence.gov.uk
Then click on 'Vehicle Enquiry' on Left Hand Panel...
Third one down from the Home button.
Found on money saving website.
That's what i used used.
Might have been on a private plate?
looking at pics, it had a red I, silver T D, which is 110, also clocks are black, 130 and 150 in the tdi coming with white, also you can see on the gearstick it has 5 speed ;)
