Ibiza cupra faults
Smoki333
472
Wiltshire
VAG-COM Version: Release 311.2-N
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 6K0 906 032
Component: 1.8L R4/20VT SEA 0002
Coding: 11500
Shop #: WSC 00000
5 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
Anyone shed some light on these? i dont have an engine light on but these showed up when vagcom.
Lambda sensors are probably because i just put a sports cat on, not sure on the others.
cheers
Also noticed
:wtf: not sure how this happened!!
Is this the coolant temp sensor.??
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
looks to me that
temp sensor has gone..
battery went flat at some point
and since your cat was fitted either the lambda wasnt connected or the wire has broken
and ive seen that wre snapped before but not sure how!!?? seems common!
HoocH
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
Remove the engine cover (if fitted)
unplug multi plug
pull out the plastic clip
pull on the temp sensors and it will come out
Put new one in with new seal
refit clip
reconnect multiplug
check coolant level and top up if required
clear codes
job done 2mins + clearing codes
Smoki333
472
Wiltshire
I dont think i need a new temp sensor so i wanna try fix the wires that have come out of the plug in the second pic, how would i go about doing this, as i've tried getting the plug off the temp sensor but doesn't seem to wanna move.
Plus the plug joins to a whole loom which runs in front of oil filter, so it aint seperate and i can't unplug it from it or buy a new loom if that makes sence.
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,872
Guisborough
www.vagcars.co.uk
Don't listen to advice... But i'll tell you one thing that broken wire is about 2 foot away from the engine coolant temp sensor and will have no effect on it at all.
Granted the temp sensors can be a bit glitchy, clear the error codes see what comes back then repair whats needed.
