Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
yea im interested in this to see how it was fixed. i cant think of any other reason why this would throw the car into limp mode of its getting to much heat soak
do you still have the under bonnet carpet on ??
so if i remove the carpet that will keep the engine a little cooler, also the dv should be a little louder!
so this is were i stand at the moment. i just orderd the maf sensor,
also im looking into a new induction kit. the type im looking for is a direct cold feed system. DIA do one and pipercross do the venom 1.
i think both will keep the air cooler than a open cone filter.
also guys can you recommend a vag com?
thanks
what do you think about this air filter.
http://www.regals-motorsport.co.uk/...04v-83mm-od-alloy-neck-vector-top-p-6813.html
also i have cold feed already.
i was thinking that but i wasnt sure if the element was the same. so its ok to do that then?
