Is the Forge Split-R all bad????
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
The 007P & Spliter R are both good.
The 007 is good yeh if you like it quiet and the only good thing about the Split R is........well i tried to think of something but came back with nothing, oh actually one good thing is that you can pick them up dirt cheap cos people cant wait to get rid of them as soon as they buy them.
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
i think that would look gash with the rubber ones when i done mine i used alloy pipe and a alloy conector to join it to the maf silicone is easyer to do imo...
i do believe you had one of these at some point if im not mistaken :p:
but the 007 has to be said is a good simple design that works well...
greg.w
113
right ill go for silicon
right the list
cone filter HERE FC-07003(want to go bling lol)
45` bend HERE
the hose will join right onto the maf.YES or NO?
then since the cone filter is 70mm female and so is the hose ill need a connector.YES or NO?like a small alloy tube?70mm external diameter?
or will they connect ok?
will i need any more hose etc for it to be close to the wing?as ive seen pics with blue silicon hose either side of the maf sensor
thanks
greg.w
113
right well after finding an awesome thread from a little while ago i know what i need to take it close to the wing
jetex FC-07003
45` silicon bend
70mm OD hose joiner
i see some people have changed the hose before the maf sensor.what would i need for this?if its the TIP then it dont matter dont want 1 of those yet lol
and also what about heat shields?im an engineer so can make my own and have loads of spare metal at work.will a home made 1 work just as good as a bought 1?how thick etc should i make it?any pics of a bought 1 or made 1?
thanks
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
ah see the search button is a good tool when used...and yes the silicone hose before the maf is the TIP...wouldnt of said there was much point in a heat sheild TBH you could make one like the jabba kit has but gains would be very small IMO and its more for a show piece...
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
I had a split R not a bad bit of kit.
But I went back to my 007P only becuase it was louder through my air filter than the split R was for some reason.
Any way this thread subject was bound to ruffle up some feathers :D
greg.w
113
thanks for the comments
the tip's like £100 yeh?can i not just get a silicon hose to replace the black hose before the maf?or has it gota be the tip?
and i thought the heatshield stopped you getting heatsoak?
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
My bad thought you meant i had a split r not a cupra lol. Had both tho but the split r was sold long before the cupra lol
lol...i did mean you had the split-r...
I new you had the cupra aswell then sold it and got the skyline..lol.
what i ment was i liked your engine bay on your cupra...didnt explain it properly after my birthday drinks and such..:D
greg.w
113
just thought id bump an old thread.
is the maf 70mm?so will i need a 70mm internal diameter silicon hose?
just cos im going to purchase it very soon
thanks
