Tjena, tjena Boffe!
We aliens tend to write a lot more correctly than the UK natives... (Or is the word correct? Yeah, I can feel something biting...) ;)
By the way, you don't need to buy parts locally, do you? The beauty of the net, you know.
Anyone know where to get vacuum hose T-Pieces from? :blink: Can't find them on the Forge site
Edit: Doesn't matter - phoned Forge and they are going to post me one :D
Ok I think I get it now. Connect top of recirculating valve straight to to middle of existing T-piece and then connect top of non-return valve to N75 instead of the lower black tube.
Have ordered some vacuum tubing so will have to wait for it to arrive :)
yep thats sound correct simple really but doesmake a nice diffrence drive it without the bypass when you fit your 007 r.v and then when bypassed see if you can feel/hear the diffrence
I have the 007P fitted but part of me wants it a bit louder but not in a chav way :lol:
It is quite jerky atm, really sensitive throttle on acceleration and lift off, but has had a new MAF fitted since remap so might be part of it.
oh yeah just bypass it as soon as the vac hosing turns up then mate it does make it a bit louder the bypass but the best mod to imo on making the recirculating valve louder and the turbo spool up quicker is the t.i.p!
The tip is on the shopping list! But its a bugger to fit from what I've read and especailly in this weather...
Just done this on my car. Was quite easy and can hear a bit of noise when lifting off now. Hope it doesn't sound too chavvy from the outside :)
do you need a metal dv to do this or can you get away with the original?
I'm undecided on whether to get a forge splitter or a 007p... if i can get a bit of noise with a 007p then ill save a bit of money and get that instead of the splitter.
the forge 007p with this mod will give off a lil noise but not noticable with musicon quite as its not a LOUD noise but you MUST have an uprated reciculating valve to do this as the valve you are bypassing is thevalve thsat protects the standard shite 1!!!
i see.. looks like ill be getting a 007p in the new year then! Dont want it loud enough to be heard above music, just loud enough to be heard inside without music :) thanks for the info
I've got a used black one for sale mate ;) It has a couple of small scratches on top but I have the service kit with new O-rings, grease and piston which it doesn't really need but it will make it as good as new.
You can def hear it without music depending on how many revs u change gear at. Not really with music..its just the right loudness imo.
