what about if you log 4th gear 2000rpm, and hold it WOT to the redline?
but then your car isn't running standard code is it?
Glenn said:Long shot but knock sensors are essentially just microphones, they have to be tightened to a specific torque so that they give correct readings. If there is a noise in the engine bay at the same sort of frequency & amplitude as detonation, it's possible that it could be triggering the sensor with a false reading. If I had a car that was pulling unusually large amounts of timing on a conservative map, I'd (a) check the condition/torque of the knock sensor and (b) look for confirmation other than timing pull in VAG-COM, that det was actually occurring - i.e check the K.S. is telling the truth.
Riddick_m3 said:james i rekon you just bought a dodgey cupra r matehheeheh on a serious note do some logging running optimax fuel and show us the comparison
m0rk said:what about if you log 4th gear 2000rpm, and hold it WOT to the redline?
Tis true.Madmile said:Intresting read.
Ju. said:Wow 70bhp transmission losses, the last run I did at awesome I got 10!! Did you do a before run?
m0rk said:the thing is - if they're able to do a custom map, why can't they customise the timing map to suit lower octane fuel?
