just bought myself an engine stand, just need to find someone local who might be able to lend me their crane.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Had my shipping details confirmed, should have all my bits in the morning. Finished stripping everything down last night for access. Removed the bumper, intercooler, rad, all cables, AC pipework etc etc. Got full access to the front of the car going to drop the DP, Mani & turbo off then will drag the engine out.
Will take some photo's at lunch as it was dark last night![]()
Good stuff mate, let the fun begin
I had a nightmare taking off the turbo on mine in the end i abandoned it and just dropped the down pipe off and pulled the engine out with the turbo in place.
It's much easier doing it on a stand, than fiddling around with all the coolant / oil lines etc....
Get some piccy's up mate, oh and when you get the engine out can you look at the cast block part number (not the stamped engine number!!), its on the back side of the block nearest to the steering rack...(im just interested to know if the BAM has the same casting as the rest of the 06a's)
Cheers & Good luck mate.
Yeh mate doing stuff like this is a cracking way to know your car inside and out, and you'll be able to stand back and say i done that !!!
Thinking of the down pipe, i had to wiggle the engine off the down pipe due to the studs on the turbo, if your planning on selling the k04 stuff and down pipe it may pay you to get the car up on axle stands and remove the front part of the exhaust..... it'll have to come of anyway to make way for the "girth" of a 3"er
I was like a kid a christmas when i knew my turbo was on its way !!!! i couldn't stop looking at it.......... i may have a problem
Unbolt the downpipe then the lines can come out with the engine/turbo
)I dont know if you have any, but the sockets that are for rounded off nuts that cut into them to undo are handy (What an amazing description)
Just thinking about the heat making them a nightmare to undo
I have a set of thesehttp://www.amazon.co.uk/Irwin-Bolt-Grip-Remover-394001/dp/B0000CCXVZ
