k03s owners please read :)
flashbsd
hey people.
Im getting negative deviaton errors, can somebody please post a photo of their actuator on their k03s (which has never been touched) so i can count the threads to compare to mine?
Mine is a k03-058 if its any different.
Or can somebody measure from the top of the forst bolt to the end of the rod in mm so i can adjust accordingly.
:cry:
flashbsd
interesting... hmm :) i shall check the new IC pipework and report when fault occurs again, usually happens when giving pasty in 4th/5th.
flashbsd
cheers matey, ill do it laters :)
Checked all pipework , all is fine and dandy, tightened every hose clamp to double check, logs it is.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
What remap are you running Russ (and simon)?
Martin - did you get the boost controller? does it do it if you turn it back slightly?
Olly20VT
1,234
Stroud Glos ,England
it looks far to far up the rod (to close to the end of thread) IIRC if i get chance i'll check mine and post it up tomoz, but i do agree that you realy shouldnt mess with it.
flashbsd
it happened with 11oC outside temp when the car was cold too, hit 13psi in 3rd and it trew into limp mode.
Although for the rest of the time it was fine??
I did some logs, but they were pulling back majorly,
no boost controller yet, going to get nicks once his has been removed :)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
can you do a leak back test on your DV?
I knnow of a couple of bailey's that 'broke' after fitting them the wrong way round
flashbsd
i got the forge 007p, did a leaky test yesterday, came out fine :(
Nov 2, 2004
9,335
South Wales
Sounds to me like your map is asking for loads of boost, add that to the fact you dont really have a tried and tested FMIC and standard downpipe and cat and your gonna get some problems.
Still would like to see some logs of 115 and 118 tho.
