k04 ibiza
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
looking good hooch, so why are you making this conversion sound so easy then when everyone else is avoiding it like the plague, what needs to be done to get it to go, you got a breakdown of the parts you've used?
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
custom manifold seems to be the biggest adventure, plus custom downpipe
and with the amount of posts regarding oil feeds/returns i guess he had abit of a mission with that
rest should be straight forward id guess, just nick parts from a k04 equipped motor
acidstrato
Dec 9, 2004
5,942
i think he mentioned it somewhere that it was...looks cast iron doesn't it? or is it mild steel?
most 20vt manifolds look the same...(ibiza, golf, leon etc) that looks like something from outa space
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
Its currently running at 19psi and dropping to 14psi!! i have a fualt code with the n75 so i guess it isnt boosting right!? all will be good when the boost controller is on...2morrow!
well spotted with the wheel bolts, living life on the edge with 3 at the mo!! lol
It depends how technical you are, it by all mean isnt easy but i like a challenge!
Im selling the complete kit for a k03 to k04 ibiza conversion soon! well once i have the gt28rs running!
its no custom mani, just a k04 mani!
big probs are:-
oil return pipe
down pipe
water feed pipe
water pipe that runs to the heater matrix
and last but not least....sorcing the parts at a good price, with out this it isnt worth it!!!
Ive been thinking about producing a fitting kit and selling it, includes DP, oil pipes, water pipes! then all you would need to do is get hold of the other parts e.g turbo, tip, maf, etc but dont hold me to it!
Im running standard injectors at the mo, need to get a wideband lamba to see what the deal is there
HoocH
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Looks like the stock AMK/BAM one from the top. Wonder why he said he had to get a custom one?
h17och
Sep 1, 2005
3,504
Dunstabubble
im not driving it! i had a quick look on vagcom and it didnt seem to be running lean! i no you said it isnt that accurate but its an idea!
im gonna hold fire untill i get the lamba probe!
i spoke to a lad who was running k04 ibiza awhile ago and he said he ran standard for ages as they just (maxed out) do the job!?
i have injectors as you well no mork so i may drop them in on the safe side!?
h17och
Sep 1, 2005
3,504
Dunstabubble
feel...just read my posts on page 1 and i do say its custom!? dont ask my why because like you said its a bam manifold!
HoocH
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I was suprised you didn't have them fitted........ your MAF is underreading & will just not put much fuel in.
What map are you running? if revo - I'd stick it in stock too.
As discussed above, the stock probe on the Ibiza is for emissions control only, not for a/f ratio - so it'll still get lambda=1 for an MOT test, but the fuel control for WOT won't be able to be read
If you stuck with the OE maf and OE injectors that'd be safer - at least the ECU will accurately read the level of air going in.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
so it's under reading then............ common sense tells you that if you think about it.
bigger cross section of air will pass, and the MAF will read a smaller percentage because of this.
if you use PIxR^2 you'll work out exactly how much it's under reading.
either have stock MAF tube and stock injectors in stock ECU mode, or new injectors & MAF (doesn't matter what element as they're all the same give or take) and still in stock mode
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
what have you done with the heater matrix hose then? i can see its been changed for a silicon one, any chance of a talkthrough of what you've done?
h17och
Sep 1, 2005
3,504
Dunstabubble
basicly the water pipe was crossing the turbo intake, so i cut the pipe back, clamped on silicone hose and went under the tip
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
Mork why not use revo?
been told by revo kev (via vagtech) that i can run revo stage 2 with settings on max!?
HoocH
