schnipps
237
Weird knocking noise from front wheels, not sure if its drivers or passenger, gets more frequent the faster you go and basically feels like there is something in the tyre hitting the ground, a bit like going over rumble lines or chevrons. There is visibly nothing wrong with the car though steers fine. Any ideas?
check the tyres for a wavey feel on the tread. I found this on mine when I purchased it and was told it was caused by over inflation. I also found one of the wheel bearings was soo badly worn it was trying to pop out of the joint causing a loud knocking noise. Had this replaced too and all was ok.
