mr&mrs
As title really.
Only happens when car is in gear.
Does not do it if I knock the car into neutral.
Ideas please?
Been told a number of things by the garage....
Clutch cap?
Clutch?
Wheel bearing?
C.V Joint?
Any response/advice would be much appreciated....
What kind of price would a CV joint cost to sort?
I know the garage said they charge £45 per hour labour...
Thanks Dave
Anybody else have a theory on this?
I have this problem as well, car only making knocking turning right whilst in gear. Mine is caused by the rear silencer mount being snapped off the exhaust. It can be fixed by re-welding or replacing exhaust.
Don't know if yours is caused by the same but if you let the car idle then reach under the car from the drivers side and push the exhaust over. If this causes it to rumble it could be the exhaust.
