KO3 turbo + Leon charge pipe sizes
Deleted member 39269
Right then folks, i have a ko3 fitted to my cupra with a leon charge pipe
bassically i want to away with that charge pipe and make my own. all i want to no is what size is the outlet on the ko3 (mm) so i no what size of reducer i need
and what size the charge pipe is. i had a quick measure with a tape measure and i think its 55mm but i want to be sure before i order any parts up!
thanks for your time
ok mate, i had a look through that thread earlier and i went and measured mine and it looked like 55mm so i thought i would double check
can anyone confirm it is 60mm i need? and a 60-51 reducer
all i want to no is that is the external diameter of the lcr at the front of the car?
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
iirc the lcr charge pipe is 60mm...
i would just use 60mm for the charge pipe makes it easyer for the fmic aswell no big bottlenecks...
the top of turbo is 51mm from what ive read...
So go 60mm pipes then? my alloy pipe comes up from the fmic to a black 45 degree bend then onto the charge pipe
I was guna chuck the lcr pipe, and replace it with various silicone and alloy pipes and just need to no the size of the charge pipe cause i dont have a vernier caliper to hand
