chedg60
installed my KO3s the other weekend and having problems boosting over 14psi I remapped again with a revo and still only boosting 14psi ???
the only way i had it boosting more is with the actuator wound all the way up (which i only done to test it then wound back to middle)
any ideas i have n75 H valve and samco tip and forge 007p
thanks
Its prob just the settings on your REVO map....
You have proved that tghe turbo can boost more than 14psi so its not a hardware fault.
Looked on vagcom and looked at the requested and its only asking for 14psi
loads of examples of limp mode on here - mainly from N75J/Revo.
I´ve searched this topic and my impression is that the N75J works on some cars and hit limp on others(different maps thou) I guess I have to find out the hard way as my J-valve arrived in my mailbox today. Im currently logging with vagcom and adjusting the map with select+ switch at the moment(was to be precise as it started to snow a few days ago) so will try the valve when I reached the optimal settings (hopefully B9 T9) Anyway, thanks for your point of view Dave...
Prebs
