Yeah unfortunately 1000 quid or so is not what I want to spend! Way too much. My days of throwing loads of money at cars are pretty much over now.
Just want a reasonable replacement for the shagged crappos I've got on there now.
Can I just run a theory past you guys please?.....
Basically, the more your lower on coilies the harder and more bouncy the ride is gonna get.
So would I be better off going for some that have a bigger range of lowering? So say you've got two sets of coilies, one which lowers to max 60mm and one set goes to 100mm max. At 50mm reduction in height the first coilovers are nearly 80% of their max, whereas the second set is only at 50% of its max lowering.
So does the second set produce a better ride due to more damper travel etc, all else being equal?
For instance, FK konigsports go down to roughly 90mm reduction. So at 50mm you've still got plenty in hand. Well that's in my head anyway!
thoughts please?
What about the konigsports? Big drop possible. Koni dampers. Height and dampening adjustable. All for 650 quid.
And what about the ones where the damper retains maximum travel at any height, like apex rdx and bc racing? Would you get loads of arch/tyre contact if all the suspension travel is retained?
Sorry for all the questions!
Will
