gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
EML light came on again last night, so i checked the codes with vagcom. It threw up the code for maf signal too low, but the maf was only replaced last month. Is there anything else I need to look out for?
not all up on this 20v vagcom voodoo myself fully sorry but wasn't there a test log you could run to check the maf ???
Yeah there is, will get a test run asap. But i'm fairly sure its not the maf, its brand new, and i was very careful with fitting
Mate you cant rule it out until its been tested ... get it on VAGCOM and log the MAF and see how its running first :)
Run block 002 in 3rd gear to red line ...
