Alignment is just making sure the wheels are pointing the right way (toe), and geometry is making sure toe, caster and camber are set right.
As there's no caster, camber or toe adjustment on the back, and no caster and camber adjustment at the front MOST geometry checks would be pointless, although a good place I know seem to be able and prepared to loosen front subframes and rear beams and giggle them about to make what adjustments they can.
Front end on LCRs seems particularly susceptible to bent lower suspension arms and other misalignment problems. Probably the compression "damping" being so hard...
...rear beams and giggle them about...
was going to mention that it's is possible to change the camber on the front of the Leon.... need to get mine checked out, as I'm getting excessive wear on the inside edge of my front tyres.....
anyone know a good 4-wheel geometry place in the East Mids ?!?![]()
Can someone recommend a company to do a geometry check, able to adjust camber up front and perhaps do some jiggling to get things as good as possible in the NW/W/W/SW London area?
Most of Bucks, Oxfordshire, Berkshire and Hampshire and Surrey are within reach as well.
Just tired of the usual put it on a computer, adjust what the computer tells them, say they can't adjust the camber or do a thing with the back
I used APS in brackley, they have a biessbarth and also move the subframe to achieve the results they need..... very knowledgable.
Pat i didn;t know there was one in MK. how much is it? APS was £50 with the VAT
£117 + vat! APS sounds like a bargain!
