just compiling a list of parts required for the job....
just need to find out the part number for the engine mount bolt.... as it's a 'stretch' bolt, and should be replaced if removed. Anyone ??
06A121011LX Water Pump With Sealing Washer
06B109119A Toothed Belt
06B109243D Tensioner
06A260849B Ribbed Belt (with aircon)
06A903315E Ribbed Belt Tensioner
??????????? Engine Mount Bolt
brave man:headhurt: i would get it done at a specialist for around £300 they would do it
inc the parts you listed ,, parts alone will cost you £170 ish from the dealer and you missed out on the 3ltrs of g12 you will need also
will be pricing up the parts next week.....
G12+ Coolant I think you mean.... 3L = 2 x 1.5L bottles @ £4 each
using www.seatspares.co.uk as a starter.... prices are:
06A121011LX Water Pump With Sealing Washer £20.95
06B109119A Toothed Belt £12.99
06B109243D Tensioner £27.95
06A260849B Ribbed Belt (with aircon) £9.50
06A903315E Ribbed Belt Tensioner £29.47 (not really needed)
Total = £102 (£72 without ribbed belt tensioner)
Have done several cambelts before, so am confident in doing it.
Would rather save £230+ and DIY it, rather than give it to someone else !!! :D
Haven't even tried ECP (with trade discount) or Trade Parts Specialist (with trade discount) ;)
thats a good site never been on there before:), take it there not genuine parts though? just had a look at my receipt from jennings the water pump had a £25 surcharge on it so parts were £145
any chance you can do me a favour and write up the individual prices for what Jennings fitted ?
Cheers :cheers:
no bother mate
water pump 6a121012x £30.62 plus £25 surcharge
cambelt 6b109119a £20.50
cambelt tensioner 6b109243d £38.83
v belt 6a260849e £19.25
coolant x3 £5.85each
total price
£171.43 inc vat £145.00 with return of old pump not bad for genuine bits if you do go for a aftermarket water pump make sure it has a metal impellar as my old plastic one was in a million bits ;)
06B109477 Tensioner Damper £35.98
06B109244 Relay Roller £13.25
also managed to find what I think are the part numbers for the engine mount bolts:
N10209603 x 2 (engine mount to engine)
N10516701 x 2 (engine mount to chassis)
Dealer RRP Prices:
06A121012X Water Pump With Sealing Washer £30.62
06B109119A Toothed Belt £20.50
06B109243D Tensioner £38.83
06A260849B Ribbed Belt (with aircon) £25.00
06A903315E Ribbed Belt Tensioner £48.20
06B109477 Tensioner Damper £65.43
06B109244 Relay Roller £19.32
N10209603 Bolt £1.46
N10516701 Bolt £1.01
Total £252.84
