Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Finally got may hands on a mint red LCR but as usual the splitter is knac****. I've bought a new one but not sure how to fit it without damaging the bumber.
Basically, push the splitter in round the side of the bumper, leave the two middle lugs till last that go into the under side of the bumper. Easiest way to ge them in is use a jack to force them up until they pop in. Hope that helps mate
I believe the just push and clip into place, I had to clip the middle of my splitter back in and it took alot of force to put it back in.
Which I suppose is a good thing don't want it coming off too easily.
Yeh, no problem fitting, but cant see haow to get the old one off. How do I get behind the splitter. Mine is an 05 LCR, does this make any difference!!
You dont need to get behind it, just start at one corner and give it a good pull and it should just pop out of its first clip, work your way round till there are just the centre two posts left. I used a large pair of mole grips to get hold of these and with a bit of wiggling and downwards pressure they should pop out too.
I found the best practise was to put my foot between the bumper and splitter and effectively stand on the foot and apply more and more weight. Eventually it came
