Today's operations
As I'm in the mood for it car repair operations continue.
Today's operations initially consist of removing the caliper carriers and the shockers.
I am considering sending the shockers in to KW to get serviced but will look into the costs and benefits of this.
The Carriers are a PITA to remove with the shocks in place as this limits the space you have to get an Allen key bit and ratchet in there.
With the shocks removed its a much easier task.
So with the shocks and carriers off and still in the repair buzz I thought it was about time I tackled a rusty spot I've had for a while.
The paintwork got damaged when I accidentally went over a curb and the side skirt got pushed off and took some paint with it.
With the side skirt removed it was the logical next step to remove the wheel arch liner and scope about in there too. Would be interesting to see what 8 years of dirt looks like, lol.
Before
After
What 8 years of muck and grime looks like
Next up is to clean this area and scope out what needs done.
I've got some Kurust coming from a mate so will remove all loose pieces and flatten out the area without removing too much paint then coat areas with Krust, Primer then top coat.
Images to follow.
Anyone know how much coilover
service is from KW?
