Well I'm no expert but your actual boost isn't spiking and settling like normal maps.
yours is peaking at 18 PSI and settling at 17 PSI.
So your actual is never meeting the requested which usually happens then the boost is rained in by the ECU.
This could point toward a boost leak but as I said I'm no expert
According to your MAF readings your cars BHP is about 240 BHP.
Did you get it RR'd before and after map?
I would start with changing the DV to a Forge one and take it from there
Are you still running the standard spring in the 007p?
Might try a stiffer spring
Yea still have the green in but have put a post in Forge section just now so see what they comeback with.
Just out of curiousty how you igure out the bhp from the logs I posted?? Fairly new to the whole VAG.com logging malarky thats all....
Ed
stupid question but hows your exhaust, lot of years ago I had a ren19 16v and the exhaust collapsed inside, it was fine round town but put yer foot down, nasty hissin and no power, just a thought prob really stupid!
Thats exactly what happened with mine when i had a boost leak it was much more noticeable 4th onwards. I would have another nosey mine was loose on 1st intercooler hard to see without taking the undertray off if you did not all ready do that
Did you find a solution? I think I might have the same issue! My MAF reading is also at 192 MAX, so around 240, the RR gave 242hp, so is seems like an okay comparison.
I have the BMC CDA-SP12, which I think is making that sound! May'be it the filter thats to restrictive?
I tought of that too, so I might give it a go, how are the HKS foam filters?
