LCR Spark plugs original vs NGK BKR7E?
May 13, 2007
1,017
Denmark
Hi!
A chap in here pointed out for me that I shouldnt be running with the NGK BKR7E R and be using the stock ones.
But isnt it suggested to use a colder plugs with a remap? Or will the stock, (which I saw rated to 250hp) be fine, as long as they are changed often?
Another question! Is is OK to clean "new" spark plugs for carbon deposits?
http://espeloev.dk/carpics/IMG_6055.jpg
Or should I just go for new ones? (6000km old, running lean for the first 3000km)
Lee M
Stick with the standard plugs, unless you are getting problems.
I've had my map for 2.5 years now and I only changed my plugs on the last service, that was because they were due and not because they needed changing. Done about 25k miles with them.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
PFR6Q is standard plug (NGK) if you want the original one back in
a lot of higher boost car benefit from running colder (higher number) plugs, sell some up to 9/10 on some serious cars
personally i would stick with what you are using as looking at the pic they seem to be fine and running ok - standard 6's usually come out of some with a more orange colour which is just as good so best of both world's really
the PFR (platinum) is a tougher material mainly designed for longer servicing schedules
May 13, 2007
1,017
Denmark
So when I change them around 12.000 km, I could just stick with the BKR7E R? The car run fine, I just discovered my car was running lean, so I thought some new ones/cleaned one would be better, to start from a "fresh"...
May 13, 2007
1,017
Denmark
I know it been a while this thread was ongoing, but, what bout the insulation on these plugs? Isnt they a bit burnt/heated?
