CR machine the inlets too thin, under the groove section it literally is wafer thing
Agreed and if it's a non original housing we can only guess the tolerances in there machining, it was a snug fit going on, heat cycles and sealant may have created to good of a fit over a already thinned housing.
I still think it will be ok fitting the adapter over this, I gave re tapped it so the grub has housing to grip on.
It's not ideal obviously but can you see any further negatives?
Sent from my GT-I9300 using Tapatalk 2
....in the Irish tried and tested manner and proceed to order off of Bill, because he's competent.
... has been nothing but a complete pain in the fckin arse from the moment I started to deal with them, I wish I never heard there name and could never recommend them based on my personal experience, i curse the day I decided to get a ...
If it's any consolation, this is exactly how I feel about the FrankenTT's FX400 clutch. It's out of the car for the FOURTH time right now. Garbage.
V3 v3 v3![]()
Flow is not a issue from the v3 and it's 40mm holemy car is pulling 286gs with more boost available when I sort my fuel pump out. But I agree no point changing from the 034 unless it fails.
You need to post logs, sir. Compare your times-to-speed when maxing 265 versus 285. I've no doubt you're seeing those airflows (on a Garrett, yes?), but it's a question whether the added flow is actually a benefit.
