Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
My 98 terminals was in a heat wave mate (only run it once, and only had 4500 miles on it) and i'm pretty confident it will be doing 100 mph terminals this year (April time). I do hope you're not suggesting that a standard 20vt is quicker mate? And they don't do 100mph terminals standard do they? Considering yours is modded?S1MMA said:with your 14.2 @98, it is fair to say that your cupra will be quick in the first few gears - no doubt. And the terminal being 2mph less than even a standard 20VT does suggest that top end the 20vt would have the edge - so you would have had to do some good work in 1st and 2nd gear to beat a stock 20VT time (of 14.5s)! I've recorded over 101mph terminals in mine - as you said this may be predominately down to CD factor, and I think gearing also.
In that 1/4 mile video of a revo LCR vs a chipped coupe 20VT, the leon does beat the coupe off the line (has some beeping TC system I think?) and stays ahed through second gear. In 3rd the coupe comes flying back, and I'd agree that in 4th the 20VT would have a noticable advantage over the revo LCR. 4th gear in a 20VT is good for nearly 140mph. Have you guys seen the vid?
