Leon cupra tdi 150 fault codes!
cupra87
Hi Guys,
Hoping at least one boffin can help me :)
have recently had an mot which it passed with flying colours.
The next day, a whole host of problems decided to baffle me
ECU light
T/C light
Coil light
went to have a diagnostics reading this morning and the following codes were discovered
17068 glow plug ecu
16706 Engine Rpm Sensor
17957 Boost Control Valve / wastegate
17849 EGR Valve
17552 Air flow meter
is it likely that all of these faults exist as im likely to be scrapping the car if they do lol
LeeC
17068 glow plug ecu- I keep getting this fault, while it is here could any1 tell me where it is located? please :)
n11tht
278
under the bonnet
as you look at the engine from the right, top right where the pollen filter is. remove the two screws holding the plastic in place then you should be able to see the module/ecu. undo the nearest nut then pull the old one out. i think i havent missed anything its a pretty easy job
cupra87
as i say im STILL learning to translate vag language lol. physical wiring loom?
the car itself is in limp mode, brake lights are still working though. no boost leaks as have checked all possibilities of this.
cupra87
fixed the problem now guys
replaced glow plugs and connectors and everything seems to be spot on now.
thanks for the guidance
