dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
Hi all currently working on a mates leon cupra for him fitting a few bits and bobs and car had been standing about for a while and was a bit lumpy when started but wasnt worried about it as with all the usual checks i was confident it would be fine. Problem i have is suddenly (without me starting to check anything) the car is now just turning over but not starting! I have checked the fuses (32 inparticular) and changed the fuel relay (409 under the steering wheel) but problem still there. Pulled out the injectors (checked there was fuel there first and plently), put a meter on them and not getting any power so cant make head or tail of it. Anyone got an ideas please as puzzling the hell out of me :(
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
P1237 - 35-10 - - - Intermittent
17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
P1239 - 35-10 - - - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 35-10 - - - Intermittent
17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
P1238 - 35-10 - - - Intermittent
Address 08: Auto HVAC
Controller: 1M0 820 043 C
Component: 1M-CLIMATRONIC X0604
Coding: 00041
Shop #: WSC 06441
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01206 - Signal for Duration of Ignition: OFF
27-10 - Implausible Signal - Intermittent
anyone got any ideas? Possible i have a bad earth?
I had a similar problem on my old 106 Gti, and the problem was the speed sensor found on the gearbox, it senses the speed the flywheel turns, and mine was broken so would turn over but not start.
Worth a try but not sure where it is on the Leon.
me too, a rat made its home in my engine bay when I parked up everyday in my work garage and eventually chewed throught the lead to the speed sensor. Little sod cost me a fortune. It turned over but wouldnt fire up. If you look at the wiring at the front of the engine low down thats where mine was. good luck
ok cheers lads will have a look and try and see if that has snapped. Went to the breakers earlier and grabbed a load of relays off a golf as getting a clicking noise from behind the dash when ignition is on (checked fuel relay already). Also just noticed that the speedo goes up to 50 ish and then comes back down to zero when i try to start the car and speakers make a funny popping noise once?! Puzzling the hell out of me!
