Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
DPJ said:Bill, could you do me a straight length of hose and a coupler so my RamAir is no longer directly connected to my MAF?
ibizacupra said:What length and 70mm I presume for you, hose size etc
I can get Forge's Siliconhose.com plus coupler or Greens rubber hose & coupler
thinking siliconhose.com is blue, rubber hose being black.
regards
bill
DPJ said:LC MAF. A coupler, a jubilee clip and 4" of your finest straight blue please, oh purveyor of quality tuning gear.![]()
ibizacupra said:yes yes yes.... patience..
will get pricing monday
It will be silicon hose and Aluminium coupler for info.
Simon L said:Got it Bill. Fits like a treat now. Thanks!
As standard for the Ibiza, this elbow should come as standard. Even though the engine bay is tight like you say, and it will end up rubbing against something, i would rather it rub against the battery, than rub THROUGH the coolant bottle.
DPJ said:Thank you! No rush!![]()
ibizacupra said:70mm coupler hose in blue is £4.75+vat and is 75mm long with req'd ally coupler is £6.99+vat plus clips
DPJ said:Bill, I was trying to introduce a little bit of 'flex' between MAF and RamAir which is why I said 4".
When it's fitted together, how far down the hose will the ally coupler 'project' ?
ibizacupra said:ally coupler is 70mm long too so there scope for adjustment there too.
DPJ said:You mean don't insert the ally coupler fully into the hose, Bill? Say 25mm in the RamAir, 25mm in the hose leaving 20mm coupler exposed?
ibizacupra said:coupler can be inserted as long or not as you like into the silicon coupler.
so yea, your example works.
collecting couplers when I get a spare min and forge are open at the same time. (tomorrow likely)
