Lift off noise
Oct 12, 2005
1,013
Turbo Solenoid problem???
Over the past few weeks I have had a problem where you get a vibration through the pedals and a buzz at 2500 in most gear esp 2nd. Also noticed that when you are in 2nd and go past 2500 say to 3000 and lift off i can hear a buzz noise as the revs drop. Goes just away just below 2500. It appears to be from the drivers side. Either from engine or dash. Any I deas. I have looked on the site and someone had exactly the same symptons I have got and it turned out to be the turbo solenoid???
1,013
Looking more into it I really think It would be the turbo solenoid. That could also explain boost problems aswell!
maxcars1
735
Phil if your talking about the solinoid that sits on the drivers strut, then i have a spare one so we can rule that one out ;)
Oct 12, 2005
1,013
I dont have a clue which solenoid it is....just looking into seems like its the turbo one. Is that the N75. Would solenoid been buggerd effect boost. Cheers
maxcars1
735
IRC the MK4 TDI Ibizas dont have a separate N75 like for example the Fabia Vrs and all is controlled with this box of tricks. Do you have any fault codes that show up? It may be a faulty MAP sensor perhaps but in all honesty, *** not known any MK4s that have needed any of these parts changing
Oct 12, 2005
1,013
Just got back from the garage and they couldnt fine anything wrong. Could it be the heat shield??? *** it rattle at a certain rpm?
ta
Triple D
Buzzing vibration feeling could be from the plastic boost pipes knocking on the fuel pump........ this is a common problem on most Mk4 tdi ibizas.A bit of foam inbetween could cure it :D
My derv had it and used to do it when it came on boost.
Oct 12, 2005
1,013
The pipe on the cupras is metal. I have checked there and I cudnt physicaly move the pipe that close to the fuel pump. I wish it was that!
Triple D
Ah right :( not that then. It could of course be the DMF vibrating under heavy laod when at peak torque, is the cupra mapped at all???????
Triple D
doesnt matter matey, if the dmf is fooked, it will do it weather the map is on or off. what mileage is on the car?????
