light on dash below blue main bean light
tyrrell
89
as above i keep getting a light on my dash (x reg cupra) in the main rectangular light panel of dash flashing and beeping
its top center of the panel and is a exclamation mark....
it seems quite random? can anyone tell me what it is and how to stop it?
i have searched - please dont reply "search"
Mat
does it only come on when you're parked up? The one in top center is the handbrake light.......
You got VAG COM? could be a dodgy handbrake sensor or something, but then you should have the massive handbrake light on at the bottom also.... get it vag com'd
tyrrell
89
nope also when driving sometimes too.....
i was aobut to say the big Park light at the bottom works fine as it should even...
however the top one is completely random, i dont have vagcom either, so thats the handbrake warning light and beep?
Mat
never known a beep.... we could guess all day until it gets vag com'd
Mat
ah.... i think it may.... anything with a beep is a low something (petrol, oil etc)
Mat
does it come on when taking corners quick or qoin up/down hill..... might be a sign of low fluid. best bet, just pop bonnet and take a look
tyrrell
89
i would check the manual if i had one......
and my brake fluid level is fine....
Dan1.6
1.6 Power FTW!!!!!!!!
Sep 26, 2008
981
Chesterfield
then check the top is on tight and clean the sensor with some electrical cleaner and make sure its plugged in okay
