Remember as well as a price saving in using 225, the normal trend is to move down a width at least for winter tyres, so moving down from 19" 235 to 18" 225 is what a lot of people will be doing as the slightly narrower tyre will provide slightly more "bit" into fresh snow, I suppose it all adds up.
As no doubt you will know, if moving away from OEM type of alloys, you will be changing from sperical profiled wheel bolts to tapered wheel bolts, they will normally be supplied with a new set of alloys if they need them along with spigot rings if the new wheels need them. If your car currently has a steel spare wheel, make sure if fitting non OEM wheels, to keep a set of the VW Group wheel bolts in the car in case you get a puncture, and also a couple of spare spigot rings in case they do not survive being removed from the flat winter wheel - or the car hub. These are all very cheap items to buy on ebay, spigot rings tend to be plastic and sold in sets of 4, VW group wheel bolts are M14 with 27mm threaded length and have 17mm hex heads. Brimecc is an Italian company that provide quality wheel bolts finished in normal silver colour or if wanting to match your new wheels which will probably not allow the fitting of the SEAT plastic bolt covers, they also sell them chemi blackened, so in a black finish and they also sell their version of locking wheel bolts - and their bolt "security key" does fit down inside the counterbore of most aftermarket alloy wheels - just in case you want to use locking wheel bolts. I've been there done that for my daughter as her wheels and maybe others come with new wheel bolts which are longer than necessary, and I wanted to address that issue in case the longer bolts fouled anything(unlikely) or got covered in brake dust so much that they damaged the car's hub threads when eventually being removed. By the way the bolt "projection" on the VW Group alloys and the aftermarket alloys ended up being the same after removing the supplied maybe 33mm long bolts with new 27mm long bolts.
Maybe too much info for you, but if you read it all and find it necessary to do what I did, then you should have worry free Winter motoring when your new wheels and tyres are bought and fitted.
I think that I increase tyre pressures by a few PSI for Winter use, there is a an advised tyre pressure increase to handle the drop in temperature - maybe it is 0.1Bar or 0.15Bar - I've noted "+3PSI" for Winter use - though that is probably irrelevant as the suggested range of Summer tyre pressures spans a lot more than 3PSI! If you are a stickler for setting tyre pressures "bang on for you" then just add +3PSI or 0.2Bar.
