Lots of faults.........Any idea?
xxxmike
85
Hi all,
I have a few faults i need some help with.
I'll give you a little intro............
Steering pump (hybrid unit) replaced and since then steering has felt lumpy and sometimes goes a little bit hard if i try and steer very quickly but OK if steering normally.
Brake lights on permanently but replaced switch twice.
Had a new battery (bigger capacity)
Below are the faults, looks like it might be a voltage supply issue?
Chassis Type: 6J (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR127862 Mileage: 126130km-78373miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BK HW: 03C 906 024 BK
Component: BXW MM4HV 4119
Revision: --H11--- Serial number:
Coding: 0000071
Shop #: WSC 06402 785 00200
VCID: 68D81F32581E200141-5178
1 Fault Found:
16955 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 179
Mileage: 125971 km
Time Indication: 0
Date: 2011.10.01
Time: 00:14:48
Freeze Frame:
Bin. Bits: 00000000
Load: 0.0 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0°C
Absolute Pres.: 1009.8 mbar
RPM: 0 /min
Readiness: 0000 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AB HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 100200DB006F00B9082D00E800D300000000
Shop #: WSC 04941 000 00000
VCID: 7EF4596AED9A8EB19B-802A
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 3
Reset counter: 219
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x0083
Hex Value: 0x139C
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 219
Mileage: 0 km
Time Indication: 0
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 219
Mileage: 0 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000490581-
Shop #: WSC 00000 000 00000
VCID: 63C2081EA238435994-8036
4 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 219
Time Indication: 0
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 219
Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 219
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 219
Time Indication: 0
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 046100346
Coding: 24882BE888610100003000007E0B1CC80040400F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 3E74996AA91A4EB1DB-806A
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3110
Serial number: --------------------
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3110
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3110
Coding: 000000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3110
Coding: 000000
3 Faults Found:
01758 - Bulbs for Brake Lamps
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 254
Reset counter: 221
Mileage: 126036 km
Time Indication: 0
Date: 2011.10.02
Time: 20:56:57
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 2
Reset counter: 221
Mileage: 126036 km
Time Indication: 0
Date: 2011.10.02
Time: 20:56:57
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 3
Reset counter: 219
Time Indication: 0
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA0D H09 0018
Revision: -------- Serial number: 003DW00BX8X4
Coding: 003044
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 428CED9AD5E22A51BF-8016
Crash sensor for side airbag: driver side:
Serial number: 3496GRB402PCOCQ794K6
Crash sensor for side airbag: front passenger side:
Serial number: 3506GRB402TCOCQ6VBS
3 Faults Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 219
12666368 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 219
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 219
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 901 HW: 6J0 920 901
Component: KOMBI H07 0110
Serial number: 00000000000000
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 65C61606640C3D697A-8030
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 219
Mileage: 125971 km
Date: 2017.05.10
Time: 00:00:54
