So I tried to fit it and I run into some issues. I cant find this adaptation in the 09 BCM module:
Erweiterte_Fernlichtsteuerung
New value: AFS, FLA, Fernlicht (GLW,MDF)
Other than that I think I coded everything else I found. Specifically:
in 09 Adaptations:
Fernlicht_assistent-Menuesteuerung Fernlichtassistent
Change to "Present"
Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung
Change to "Present"
A5 module
coding:
Byte15 bit 5-7 changed to AFS_coding_light_assist, Matrix beam
B4 Multifunction module
coding:
I overtook from the different
Formentor with factory fitted Matrix headlight.
Still not work tho. Here is a log:
Code:
Friday,01,March,2024,19:50:39:26615
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5WA 937 086 AE HW: 5WA 937 086 L
Component: BCM37w_M028 0175
Serial number: BXJ53F020522940 Dataset Number: V03935364GJ 0001
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007_SK38.rod
VCID: 1470BCE8AEFDF0DA9BB-8040 SFD
Wiper motor control module:
Subsystem 1 - Part No SW: 5FG 955 113 B HW: 5FG 955 113 B
Component: FWISCHER_MYJT 067 0053
Serial number: 907353F0402207404486
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 43365081X81A955555B0
Light switch:
Subsystem 3 - Part No SW: 5H0 941 193 AG HW: 5H0 941 193 AG
Component: LiSi H04 0513
Serial number: TW571427042200011512
Roof electronics control module:
Subsystem 4 - Part No SW: 5H0 959 561 AA HW: 5H0 959 561 AA
Component: -VW----LINDA- 503 0822
Serial number: MW3LND14042200011194
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 GA HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000027042208490358
Rear lid opener control module:
Subsystem 6 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 39322852
left tail lamp 1:
left tail lamp 2:
Right rear tail lamp 1:
2 Faults Found:
90638 - Databus
U1123 00 [00101111] - Received Error Message
[Leistungsmodul für LED-Scheinwerfer links - Fernlicht defekt]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:43
Terminal 15 status: On
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.3 V
Outside temperature: 15.0 °C
Light switch position: 0
90894 - Databus
[Leistungsmodul für LED-Scheinwerfer rechts - Fernlicht defekt]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:43
Engine run: OFF
Voltage: 12.3 V
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 5WA 907 530 Q HW: 5WA 907 530 G
Component: GW2020 High 756 7300
Revision: -------- Serial number: 771049050022091 Dataset Number: V03935348MH 0004
Coding: 0000838D0F00000000000000012303527101611B03000100030100000001010000000000000000000000000000000000
GVL: 3D0008000208C0CC80008002C800004004004002404000000000000000000044
ASAM Dataset: EV_GatewMQB2020 005011
ROD: EV_GatewMQB2020_004.rod
VCID: 56F486E0788122CA25F-8002 SFD
Generator:
Component: 5-01-14-01-04
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 4629999405
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 3F0 907 155 HW: 3F0 907 155
Component: U13 DCAC H14 0017
Serial number: 00000000000003297161
Multifunction steering wheel control module:
Subsystem 4 - Part No SW: 5FA 919 719 J HW: 5FA 919 719 J
Component: E221__MFL-PR6 H02 0110
Serial number: PR6-0440059186221277
Steering Wheel Touch Recognition Control Module:
Subsystem 5 - Part No SW: 5FA 959 542 C HW: 5FA 959 542 C
Component: KLR 089 0023
Serial number: 3136195AA22184188703
1 Fault Found:
1049110 - Hybrid Databus
U1534 00 [00101111] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:41
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 B HW: 5WA 907 338
Component: FCM2020 Low 014 1447
Serial number: 046908021415026
Coding: 00000000090007CA06000910020003070300000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 004012
ROD: EV_MultiModulContiVW38X.rod
VCID: 4DC6698C4D576112945-8018 SFD
7 Faults Found:
0031 - Power Output Module for LED Headlamps; Right
U1171 00 [10001001] - No Communications
[KN_LED_DK3_R no communication]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:41
0023 - invalid data record
B2005 00 [10001001] - -
[Data set AFS not valid]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:38
0024 - invalid data record
[Data set MXB not valid]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:38
5350720 - Left Matrix High Beam
C1175 54 [10001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:38
5350976 - Right Matrix High Beam
C1176 54 [10001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:38
0032 - Headlight
C107E 54 [10001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:38
13705487 - Databus
U1121 00 [10001001] - Missing Message
[Daempfer_03 data bus missing message]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 34291 km
Date: 2024.03.01
Time: 19:48:39
End----------(Elapsed Time: 01:40, VBatt start/end: 12.3V/12.2V)-----------
Still needs to upload the dataset file but any ideas what am I missing in
coding/adaptation? Thanks a lot!
