Mk1 1.0 restoration
grotmeister
168
Ok back on the case now, sadly Mrs G was taken ill just before xmas and still v poorly so had to leave car thing, have sprayed the doors and guess what? Yeah it's a totally different colour so am going to spray the rest of the car now, full of dents anyway. Will post some pics soon.
grotmeister
168
right where were we.......... just about finished converting my garage into a spray shop took a good four weekends. going to start on the body repairs this week
<a href="http://s9.photobucket.com/albums/a98/grotmeister/?action=view&current=sprayshop.jpg" target="_blank"><img src="http://i9.photobucket.com/albums/a98/grotmeister/sprayshop.jpg" border="0" alt="new spray shop"></a>
grotmeister
168
oops
grotmeister
168
Finally got round to doing some spraying. I've done the front bumper first to make sure the paint lays on ok. Here's some pics. I filled the grooves in the upper bumper and rubbed down those irritating dimples in the lower bumper. first couple of pics are upper & lower in plastic primer, I sprayed the grille inthe lower half with metallic black:
Next pic is bumper reassembled and given 2 coats of high build primer rubbed down with wet & dry ready for the basecoat:
Now have given it a basecoat and then removed the masking paper:
And finally...clearcoat; think I need to give it another coat of that though...
grotmeister
168
Spent most of sunday rubbing down the body, not quite finished yet; v laborious job! I need to remove the headlining to get the aerial off as well, still, looking on the bright side I shouldn't have too much masking up to do coz I've removed as much as possible from the body......
grotmeister
168
How?? the nut that holds the aerial base to the roof is above the headlining, can't see how i could get that out from the top. any advice much appriciated!
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
not sure of the set up of the arosa's but when i had to change the aerial base on my ibiza i just gently pulled the back of the headlining down and sliding a spanner in to undo the nut. if that helps:)
thats the way to do it remove the rubber seal to fit your hand in the space between the linning and the roof if there is one or its just a case of removeing a plastic panel or two its dead easy.
there normally 13mm nuts.
ArosaRacer
Wee man returns in a fL mk2 cupra
Aug 28, 2005
2,299
18
45
Bayview, Kent
its a 22 mm nut, be really carefull and prise down the headliner, slide spanner in and losen the nut, i will check when i get up later what size it is
Boo
The original wee beastie
Nov 12, 2006
1,868
Eastbourne
Good gawd ! Thats the most unloved but, loved Arosa I have ever seen. Its like the ugly duckling before the swan emerges !! Methinks your enjoying this project far too much :D Good work !
