mk3 ibiza cupra headlights
Apr 12, 2008
539
Here in Croatia headlights are very expensive, especially original Cupra ones...ive heard that u can put them in the owen so they heat up, and then you can open them...never tried though...
cupracaddy
aw ok then wanna open them to do a little tweak to the insides lol ill have to buy a set and have a go putting them in the oven sounds like a laugh
thanks
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
it is ok to put them in oven as the heat softens up the bonding glue so the can be parted a few people have done this as they have changed the inside colour
Apr 15, 2009
2,189
Midlands
as long as the lenses are glass (which they are) and not plastic then wack them in the oven
Ive done it loads of times with other cars
I did my cupra lights to reaseal them as one was condensating inside
Jan 8, 2007
2,958
Wiltshire
Anyone know how much OE Cupra headlights retail at?
mine too are plastic could do with resealing one of the headlights as it keeps on getting condension in it[:@] may be do it when jake resprays the car:D
This might be air getting in from behind the lens through the cover? Are they properly secured and are all bulbs seated correctly?
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
from what i can see robbie looks to be seated ok may run a bit of silicone around the outside of the bulb see if that does anything only seems to be the drivers side
Apr 12, 2008
539
here in Croatia cheap noname low quality copy of non-cupra headlight is around 80£
i belive that original cupra headlight would be at least 200-250£..
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
Im going to be doing the oven technique soon, it does work.
When i split my corsa lights i used a head gun but i tried the same with a ibiza headlight i got free and the glue was much stiffer so didnt work.
cupracaddy
thanks for all the tips gonna give it a go :) hope they dont melt
