MK4 Ibiza FR TDI De-Cat
FR8ZER
PD150 FR+
Feb 8, 2010
58
East Ayrshire
guys just saved me a search thro an over crowded search result :p
where is the cat on the ibizas, is it on the way down from the manifold, or on the flat under the car?
So it seems welding a wee pipe in , replacing the cat is a nice wee upgrade??? i know all the mot jargon, my mates an MOT tester, but never had a mate of mine, de-cat his turbo diesel :)
Forgot to put in here, does the de-cat end up with any warning lights etc on the dash etc?
cheers frazer
1,892
Derby
im a mot tester the smoke tester we have counts down from 5 secs then full load for 2 secs let it idle if its over you have to do it again max of 6 times if its readin over the limit its a fail.
just checked my smoke test results from the past 2 years
results befor i had a good map on and still had my cat on are
1.70
1.17
1.29
zero drift
max aloud is 0.10 actual is 0.00
mean value
max aloud is 3.00 actual is 1.39
last years results with better remap and de cat fitted are
0.09
zero drift
max 0.10 actual 0.00
mean value
max 3.00 actual 0.09
just shows havin a better map and a decat dont make your car smoke as much
some people might think im a mot tester and my car passes every time but it dont i want my car to be safe.:)
FR8ZER
PD150 FR+
Feb 8, 2010
58
East Ayrshire
gonna do this on thursday lol :p
Is there any sensors in this section that i'll be removing?? hoping it should come loose wae no 2 much bother :) should be able 2 get it off wae 2 ramps.
Cheers frazer
krussel
1,713
Hertforshire
Cheers frazer
Hope it goes well :D
If you get a chance take some pics and note down a basic guide as this could be a great cheap upgrade. A lot of folk do this on the x type 2.0 d without any probs.
krussel
1,713
Hertforshire
I know it will prob cost but can you simply buy an after market down pipe which does not have a cat and fit that as my welding is not all that good. :whistle:
Mar 13, 2010
822
Im sure an exhaust place would be able to slot abit of pipin in liek that for next to nothing, wouldnt take long either.
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
it does put more pressure on the turbo due to the release in back pressure. But only in theroy to be honest, its more mechanical engineers that will tell you that as appose to mechanics. It will be very sooty though when booted and reasonably loud.
Diesels only get a standing emisions test and not a under load test so can get away with a decat.
SWANSWAY CUPRA Dealership
