Cheers pal the radio signal is very good also so happy with that. Standard aerial needed some hefty pulling to remove.
Does the aerial just pull off then, or is it screwed on?
It's screwed on mate but also has an anti theft device at the tip of the thread you can see it in the image.What I did was unscrew it as far as it will go then placed one hand on the aerial base and gripped the aerial with other hand and pushed the base down and pulled the aerial up simultaneously. It does take a lot of force but it will have it.Also helped moving the aerial side to side whilst pulling up.
This is the one mate inexpensive and does the job
http://www.ebay.co.uk/itm/BLACK-CAR...arts_Vehicles_CarParts_SM&hash=item58a43aaeac
Cheers bud, I take it the piece that looks "ridged" in your picture doesn't prevent the replacement going on?
I see from another post you're hoping to pick up a secondhand Triple R splitter, you just hoping to save a few quid because ive just bought one for mine and they're only £105 delivered......... has hopefully been fitted today while the car's in the garage having everything else done.
Not very long mate. Was okay for about four weeks and then started jumping under heavy load in 4th, 5th & 6th and been like that for about 6 weeks and getting worse!
Ive just noticed something very interesting here....![]()
Some job you done cleaning it, looks real well! Your clutch could be fine on stage 1, I've an 08 Cupra too and ran stage 1 for about 6 months no problems and it's running stage 2 at the minute and has since summer and it's still fine so pot luck just really and they're both Revo maps!
Where did you order the bonnet gas strut mods from? And do you have a guide for it?
Then the plates are from SCN member called Vik you can find his email address in the above thread.
Hope this helps mate![]()
How long are the wheels taking and how much Craig?
Should have it back on Thursday it's normally a three day turn around but due to dropping off at mid day(on way to work) it's going to be a little longer.
Total cost is £285 that includes the wheels,hubs and calipers refurb and also he polishes the car with maguiars. Also in the price is a courtesy car.
So currently I'm rocking his mk3 golf gti
