Ok, well today consisted of fitting my boost gauge and led stop/tail bulbs.
Also, here's some pics of the slight damage to the rear of the car:-
I'll take a quick vid of the stop/tail led's when I get the chance, but first, the boost gauge!!
I bought an electronic boost gauge off ebay for £34.99
http://cgi.ebay.co.uk/WHITE-AMBER-B...arts_Vehicles_CarParts_SM&hash=item43a4c9ada4
And I bought the RGM a pillar gauge holder (plenty of these about!)
Anyhoo, I started by gaining access to the back of the fusebox/dash/headlight switch:-
Undoing the torx bit screws along the edge of the exposed fuse box holder and the side of the dash gives you access:-
Removing the scuttle panel gives access to the bulkhead, I drilled a hole next to the engine loom entry and fed some wiring through (wiring with the kit was no way long enough for what I wanted!)
And from the side of the dash:-
I tucked the plug and wiring behind the seal trim:-
Right so, my boost gauge being electronic needed the sensor to be wired in. I figured this configuration:-
Red and Orange wires (orange wire makes gauge light amber at all times) Connect to Blue/Black of dimmer switch wiring
Black wire connects to thick brown wire of dimmer switch wiring
