Handbrake changed and Armrest fitted
Cupra R handbrake genuine from Ebay feels better - also my original handbrake nuts Only Hand Tight!!!
New genuine Seat Arm Rest also from Ebay
Up - showing CD holder (Ebay)
Down
drove about 50 miles with it today and it feels comfortable no squeaking or any other noises - so overall Happy :D
Dyno Run today at Got Boost
heres my results
My first run was:
Maximum Power - Wheels 142.5 bhp @ 4,012 rpm
Maximum Power - Engine 176.9 bhp @ 4,058 rpm
Maximum Torque 267.9 lbft @ 1,994 rpm
Correction Factor 101.6%
Environment Temperature 11.8 C
Barometric Pressure 983 mBar
My second run was:
Maximum Power - Wheels 144.8 bhp @ 3,963 rpm
Maximum Power - Engine 175.2 bhp @ 3,980 rpm
Maximum Torque 269.0 lbft @ 2,014 rpm
Correction Factor 101.7%
Environment Temperature 11.7 C
Barometric Pressure 982 mBar
happy with that for a standard TDI 150 with a Carbonio CAI and Tesco Fuel/ Millers DPS4
Looking really good mate!
Just wondering where you got that cd holder from? Looks really smart! Never seen one before.
Also, how hard is the arm rest to put in? I was considering this, but got put off by people saying it was a hassle to fit!
ebay for the cd holder from a main dealer on there claering parts only hold 4 but works well as I have mp3 cd player installed
arm rest as andrew said was a potch but I feel worth it 1 1/2 hours maximum
I have just bought myself a set on ebay not sure of the make but they have a sticker on the base of the unit which reads "RELIABLE AUTOPARTS QC MADE IN TAIWAN"
there are chrome units with 2 angel eye ring in each lamp unit and a standard sidelight hole under the standard lamp (inner) and the Projector style unit next then the indicator hole
anyon got any idea where I could get hold of a fitting guide or similar will post pics of the lamps later
Next on the todo list
STOLEN FROM LEE69 - cheers mate
Now have my Angel eyes to be "modded" and fitted.
For anyone who want's to do the same as i am follow these basic instructions.
Remove the 4 clips holding the lens to the outer case
Then they split like this
Then break the seals holding the plastic to the actual front lens
Then pop out the plastic "angel eyes" and remove the indicator bulb cover
And it leaves you with the carcass to spray black :D
I shall update this when i have sprayed them, i am waiting on some H1 hid bulbs arriving to make full use of the projectors :D
After 6 light coats of matt black, just need to let them harden then I'll rebuild them up.
did your handbrake cover come as just a floppy kind of cover?i put mines over the original one....
You can get ones just like the lights you've bought on ebay, but with a black / dark background instead of the chrome.
Can't find them again now, but are from Germany.... and are just short of £200 I think!
was thinking of replacing the 501 type bulbs 4 each ring with 501 type LED
also when you say you have removed the indicator diffuser do you mean you did not put it back in when you re assembled them as i have also removed mine
