My DIY open cone heatshield
Ovni_cupraR
Yellow Peril
Oct 25, 2008
131
Maidstone, Kent
Well after fitting a green open cone to my LCR i felt that if anything the standard airbox performed better. I loved the noise it made and didn't want to get rid of it so instead I decided to make my own heatshield using the bottom half of the standard airbox as the base with an aluminium shield fixed to it, so now it's more of an enclosed kit.
All I can say is I can definately tell the difference now the shield has been fitted, now it seems to spool up a bit quicker than before and just feels less sluggish than with just the open cone. Also I have got rid of the oem air feed and fitted 3" tubing. Heres the pics:
The only thing I need now is a good scoop from the front of the grill to attach to the cold air feed.
sheffboy
avoiding potholes
May 25, 2007
655
that looks really good mate!
you've got best of both worlds now.
Get em on ebay as a sideline ;)
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Looks good. Back in the day I fitted open cones to my Ibizas, with direct cold air feeds, would deffo of employed you to do this on mine... cheaper than 'other' mnaufacturers... lol
Mike
Ovni_cupraR
Yellow Peril
Oct 25, 2008
131
Maidstone, Kent
Thanks for the comments, I measured the bottom half of the airbox then it was just trial and error from there really, I made a cardboard template first and kept adjusting until it was right.
cheers
Ovni_cupraR
Yellow Peril
Oct 25, 2008
131
Maidstone, Kent
With the bonnet lining on yes... but I've removed mine so there is about an inch gap. I might run some rubber tubing along the top of the shield so it seals against the bonnet.
cheers
drue1
193
kent
looking sweet matey.ive not got a cone filter ive just drilled my airbox and fitted a pipercross filter inside but i need to run a cold airfeed into mine
dg-1984
254
Glasgow'ish
Looks good mate, could you not modify the top half of the original box, so that it keeps it enclosed, or you wanting to see the cone when the bonnet is up?? ;)
Aug 24, 2007
800
nicely done mate, may have to copy you though ;)
I kept the lower box fitted with my cone but never thought of this style of shield :)
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
fancy making me one of those pal??
i reckon youd be onto a little earner from these....
how much the material cost, u want to send the dimensions up on here if youre not thinking of selling these so others can use it??
Ovni_cupraR
Yellow Peril
Oct 25, 2008
131
Maidstone, Kent
I could make one up for you at £20? The materials cost me about £14. I might do a guide and see if they sell on ebay.
cheers
WeeJase
pert
Jun 2, 2001
8,595
using "FEEL" battery relocating brackets would give you more room for a less restricted air flow through your 3 inch pipe to the filter.
