my gt30 nitrous ibiza cupra project
wild willy
2,323
Wales
Superb project mate, just awesome.:)
One thing though, the dynatwist your sucking through is a seriously restrictive affair especially for your engine output. Get a supersized jetex on there which you will notice the improvement in flow.
revo20vtdan
113
sunny old stockton
Well little up date i went to york raceway yesturday with a few mates to try out the car on the quarter mile for a laff
I got 6 runs in tried a few differant boost settings anti lag on and off didnt put the boost over 20psi as it was just spinning way tomuch had a great day sun was out and decent temps for the track
Runs. Secs Mph
1, 13.7. 108.16
2, 13.9. 109.43
3, 13.8. 109.82
4, 13.6. 109.72
5, 13.6. 111.94
6, 13.1. 112.73
i was happy with the times as it span the wheels in 1,2,3 then by the time i got grip was about half way lol the final run i let lots of pressure out the tyres and got a good start i got stuck in 4th gear about 20ft before the line so i ended up going over the line sat on the limiter so no dout i could of scrubbed a little more time but i'll use to day as practice gives me something to improve on :-D
crying_boy
Newbie
Jan 8, 2006
143
Portugal
very good.
but you have to put more power, here in Portugal Ibiza 6L 1.9TDi engine make less than 13segundos. and there is an ibiza 6k2 PD150 engine making less than 11segundos. you should have to overcome since it is gasoline.
You can see their videos on youtube, search IBIZA LL
ps do not get me wrong, I'm not speaking ill of your work, quite the contrary, I'm just encouraging to do better! because there is a beautiful work!
:drool:
revo20vtdan
113
sunny old stockton
The tyres are toyo t1rs 195/45/16 so theres another massive improvment i can make as where iam gainin speed is half way down the strip after all the wheel spinning
no nitrous used as i cudnt even use full boost due to exsesive wheel spin so it was pointless
Rick1.8t
150
Mental car , bet its very quick when rolling, not too much giving away its power either other than the fmic and most are not likely to be seeing much more than the back of it anyway!
I bet a new inlet manifold would free up some ponies with such a large turbo, also the IC piping? - Keep it up
Agree with phil. - Friends Sierra with a gt30 did 12.9 (broke his prop second run) at 122mph. - What were your 60ft times, these are usually the give-away, 195 standard toyo tires wont help anything with that kind of power though!
What was hooch's times at the pod when he went? I remember his terminals being very high.
Rick
revo20vtdan
113
sunny old stockton
Terminals arnt high due to spinning frew 1,2,3 gears and a little into 4 my friends stood half way down the track on a few runs and said it was still spinning i only got into 5th on 1 of the runs so i think once i fit some good grippy tyres i might get better starts see what happens at the next york meeting
h7 cya
453
Mental...what a beast...low as f**k too!
Keep up the good work..gotta be some low 12s with traction and gearing corrected?
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Who gives a **** what it runs down the strip when do you ever do that on the road , imagine when it's rolling it will kill pretty much any car on the road
