are they?ive not look too much into detail but seen loads of threads that say n249 auq or bam,etc
not questioning you just wondered
Thing is though, you don't touch the valve ;)
Step one: remove hose from top of DV
Step two: remove hose from top of FPR and from bottom of inlet manifold that the same hose runs too...
Step three: connect new 4mm hose from DV to inlet manifold
Step four: t piece into same hose to connect FPR
Step five: block off any hoses remaining that not connected
Step six: remove vac res. from coil pack four
and i connect to the pip sticking out sideways instead of the 1 coming straight off the end of the valve if you no what i mean
