Need help on sport suspension for Leon 20VT-4 (4WD)
liorbn
Hi Friend
I need your help to choose sport suspension kit for my Leon Turbo 4WD 2002 model (20VT-4) 180BHP.
I prefer the sport suspension and not the coil-over
Here, in Israel there is no expirience at all with suspension upgrade, or on my model (only 20 20VT-4 cars here) so please try to help me not to make mistakes :(
How about the regular sport kit from KW ? (20081045 not coilover)
How about Kony sport shocks + springs from MAD or Eibach ?
Is it any cheap and good other manifecturer ?
I want to order it via Air_Mail, so do you have any recomendation where to order from (Wich country in Europe is the cheapest)
Lior
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
i think kw is quite firm compared to koni
probably best from a euro country such as germany or italy
also bilstein / eibach
liorbn
I'm looking for stifer suspensions (lot stiffer socks, and 20-30% stifer springs)
Is Holland cheap ? I heard that there are few cheap manifecturer ther, any expiriance with them ???
liorbn
Noting for leon 4WD on Ebay :cry:
anybody ? any idea ? Plsssssssssssssss
liorbn
No one ?? :confused:
Enybody upgrade his Leon 4WD suspension out there ???
Or all you care is power-power-power without handeling ???
Lior
matt_s
4 8 15 16 23 42
Dec 23, 2004
656
19
You may not realise this is a UK based forum and SEAT don't import the 4WD Leon into the UK so there isn't much experience of it.
Hooper
Suspension Upgrade
Cannot comment on the rear i.e. the Four wheel drive set up. But, having researched the front drive Cupra model and gone with Koni shocks and Eibach Springs, I can recommend it as being a lot firmer than standard even with the Koni's set on lowest setting.
Eibach and Bilstein kits are expensive and the shocks are fixed rate, so if you think it is too firm or too soft once fitted then tough.
The Eibach Springs are good as they do not lower as much, about 20mm and are progressive. The Konis up front are great as they are top adjustable and you can tune to suit your roads/taste. The rears are adjustable, but a pain because you have to remove from the car to adjust.
Other favourites are H & R I think, but the springs lower by 30-40 mm which would have my car beached on a speed hump about 20 m from my house.
If you purchase in the UK and export you may be able to save VAT in the UK.
