Hey guys and gals...
Just recently my cars been hitting limp mode and only boosting to 10psi, even though with my remap i usually hit around 20psi. On occasions, its gone up as high as 23psi peak, and i thought this was the cause of the limp mode. I backed off the remap settings.
Now, on the way home tonight, I hit limp mode again, and i wasnt pushing the car in the slightest. Just when i accelerated i noticed the 10psi barrier again.
The strangest thing - when i used to let my foot off the gas after accelerating, the boost gauge would snap down to the -20(vac) reading very quickly. (I assume this is normal?)
Now when i use any boost over 5psi and let off the gas, the gauge drops to -10vac really quickly, but seems to get stuck and then drops to -20 much slower. I can almost hear the dv sound like it dumps in 2 stages (noise through my CAI)
VAG-COM shows 0 errors.
I have very limited technical knowledge, and can only guess at either the DV sticking, or either N75 or N249. DV has been serviced quite a lot, so i can't really see it being the issue (although can't write it off completely) and N75 has only been on car 1yr...
Does ANYONE have any clues or links? I'm sure the strange behaviour of boost is the reason for my limp mode, but not getting any clues from vag-com at all
Please help. Thanks in advance!
