Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
My suspension is stock, my back is too bad for anything harder. It was very easy to do, just jack it up, remove the rear wheels (one at a time) and spray some motorbike chain lube into/around the rubber bushes where the rear beam pivots (just in front of the rear wheels) The chain lube grease comes in a can with a straw so you can be realy spot on with where you spray it.
Any news on your squeaky belt tensioner ? My squeak seems to be getting worse.
I have just done the same as Nath and spraed some spray grease into the bush and it seams to have done the job..
Thanks for the reply jeb
Unfortunately I don't have quite enough copper grease to FILL the void, and the car is in the air until the paint dries on the brakes lol. I have loads on the two mating surfaces, and some around the edge, would that be enough? Or would you advise I go buy lots more copper grease tomorrow?
Hi George, long time no hear. Hows the rear suspension noise on the biza ? Mine came back so hassled the dealer to sort it. Since then not a single sound. Here is what they did.
When you look under the car there is the big bush assembly where the bolt goes through to bolt it to the chassis. either side of this there are seals 1 each side that are bonded to the chassis( slim ones). They REMOVED them so the large bush does not 'rub' against the others. Just had car MOT'd and no problems. Mine is well quiet now. No grease req'd either !!:![]()
