Changes in 1.4.10
* Fixed bug in MAP sensor readings for cars with barometric sensors. This will affect boost gauge accuracy and also MPG for mitsubishi vehicles in particular. I don’t have a Mitsubishi to test against so feedback would be appreciated!
* Support for Diesel MPG readings (beta – this may take a couple of attempts to get correct).
* Support for E85 fuel type(beta)
* Fix a
problem with speech support causing a slowdown when starting the app
* AIDL interface (information and example app will be put into the wiki)
* Add a workaround for when you delete a display and sometimes a crash may happen (segfault in android libskia.so).
* Fix the missing track in the Map view.
* Fix bug in the new dashboard setting for some devices causing an intermittent blank screen
* Turbo Boost support (beta) for VW/Audi (or any vehicle that uses a MAF sensor)
* Added ‘send to back’ / ‘bring to front’ menu options for displays
* Fix bug in O2 1×2 not updating after fixing a bug in fuel trims
* Fix a bunch of quirks to do with activity state handling
