I really want to add the "Cupra" view to our Leon FR. But, I cannot find the option "view Activation" after choosing "long adaption".Hi Everyone,
I have been having a play with OBDeleven with my car (FR First Edition) and have managed to code some things and thought Id share what I have found and create a thread where people can share there findings for us all.
I have managed to code:
Cupra Display
Lane Assist Point Of Intervention (Have yet to test, but should keep the car more central rather then let it almost drift out of lane before kicking in)
Lane Assist Set To Last Setting
Lane Assist Warnings Turned Off
I know a lot of people find lane assist is already to sensitive (its already set to lowest from factory), so I might have found a solution to this too. So you can turn it off and it will remember this setting each time the car is turned on etc, so now you can make it sensitive for the motorway and only turn it on when you want it.
Cupra Display:
Module 17 (Dashboard) -> Long Coding -> View Activation -> Set All 16 Views to active -> Write To Car
Lane Assist Point Of Intervention:
Module A5 (Driver Assistance) -> Long Coding -> Point Of Intervention -> Set To Early -> Write To Car
Lane Assist Warnings:
Module A5 (Driver Assistance) -> Long Coding -> Lane Assist Off Text -> Set To Disabled -> Write To Car
Lane Assist Settings:
Module A5 (Driver Assistance) -> Long Coding -> Configuration For Lane Departure Warning K15 -> Set To Last Setting -> Write To Car
Let me know what you guys find![]()
Thanks will try tomorrow.Control unit 17... adjustments... unlocking the views
You have the Classic cruze Control? Everything Else ist SwaP Protection
You know what SwaP is?Thanks will try tomorrow.
Yes, we have the normal cc now. Is it possible to code it to acc? Or do we need to have additional details hardware / module?
HI Tommy.Hi Everyone,
Cupra Display
Cupra Display:
You mind posting the link please? I’m curious about doing this, and any side effects eg overlapping icons or similar?Found it!
Hello everyone. I think every Seat is coded differently. I drive a 2021 Seat Ateca and would like to retrofit travel assist. I can install the steering wheel myself, but I can't code it. Can someone please help me? Thanks.
Don’t need OBD11. Go to the 1st view menu (2dials) then hold the OK button for a couple seconds. After release a secret menu should open, go to service and inspection and reset them both (they are reset separately)(so go to the menu twice). Then you are done. Much safer and faster/easier than OBD11Hi everyone, just bough a 2021 Leon 1.5 and it had a service done but in the main screen it say that a service and oil change is due in a couple of weeks. How can i reset this interval with obd11?
Thanks in advance
That's the problem, I can't access that secret menu, reason I wanted to do with the obd11
Strange, but the service reset should be in basic settings, think under engine module or elektronic modules
