As far as I remember, the Leon K1 was also available with Side Assist in the exterior mirrors, i check this. Control units cost between €100 and €200. Brackets for both sides cost approximately €50. Wiring harnesses from AliExpress cost between €80 and €100.
Reactions: folpac
Hi everyone. I purchased a 2020 seat Leon FR 2 days ago, was wondering if it’s possible to enable auto high beams on the car? I have the camera on the front of my windscreen, can anyone help me pls. ( I don’t really have a clue how any of this works yet - sorry if I’m being dumb😂)
Hi all,
I'm tempted to buy a OBDeleven 3 dongle for my MK4.5.
Before buying I'd like to know if there is some kind of list what can be changed.
There are two things (for now) I'd like to change if possible: Turn off speed limit warning by default and set the personal drive mode by default.
It probably doesn't make sense to buy the dongle for only those two settings without even knowing if it's possible to set these by default so some kind of list would be great.
I got to be honest I didn't read all 48 pages of this thread and search function didn't help me either.
Buongiorno
ho provato ad attivare la visuale sport sulla leon mk4 ST 2.0 TDI DSG del 2022, la visuale si attiva con il contagiri centrale e velocità digitale centrale, ma non si visualizza la lancetta del contagiri, è successo a qualcuno, come risolvo?
Grazie in anticipo.
Good morning I tried to activate the sport view on the 2022 leon mk4 ST 2.0 TDI DSG, the view is activated with the central tachometer and central digital speed, but the tachometer needle does not appear, has it happened to anyone, how do I solve it? Thanks in advance.
@ricsport you will be better off posting in English if you want answers.
Reactions: Tell and ricsport
@ricsport faresti meglio a postare in inglese se vuoi delle risposte.
Ok 👌 thank you
Good evening. I have another question.
I’m trying to activate the alarm with the horn. I’m following a guide, but I can’t find the last option mentioned in it.
So I was wondering if anyone could explain how to do it or suggest an alternative way.
I’ve attached a photo where I highlighted the option mentioned in the guide that I’m unable to find
Thanks in advance for your help
