Odb11 help
Rafterman79
35
Odb11 - whats the score with this? Got the app but wont connect. Do i need a cable to hard wire in 1st before bluetooth pairing?
MyLeon
349
You only need to pair it with your (android) phone. No cables necessary.
I've just been playing with mine and discovered I can't do long coding at bit level.
Does anyone know why this isn't available? The tutorial on YouTube is different to mine.
2015 Leon ST FR 184 DSG
Rafterman79
35
Phone is paired for audio and calls 1st time i tried to connect it came up with a choice of 2 mac addresses chose the 1st. Havent been given the option again and it won't connect....
devJORD
OBD11 Wizard
Nov 14, 2014
387
It's literally a plug and play device. I know this might sound silly, but have you tried restarting your phone, unplugging the device and plugging it back in... Sorry to sound like BT support.
Rafterman79
35
So you do need a cable??
mattb82
38
Tamworth
This might sound daft, but have you bought the obdeleven dongle or are you trying to connect the app straight to the car?
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
The obd11 dongle connects to the cars obd port and the obd11 dongle connects via Bluetooth to an Android device running the obd11 app. Android device > obd11 dongle > car
p.eco
227
16
Ireland
You need the PRO version for long coding.
Sent from my Nexus 6P using Tapatalk
MyLeon
349
It would appear the the little slidey "Pro switch" need to be to the right.
There is no warning that Pro has been switched off! (I must had done this whilst first messing about!)
I still can't see the hex code like vcds displays but I have changed my consumption correction factor to get the dash and reality a bit closer.
Anyway, thanks for pointing me in the right direction
