Ongoing saga of Bank 1 - Lean
stren
no the one at the frint of the mamifold joinns the t to the right of no 17
stren
boost leak ?
and if you are not boosting u have vacuum in the manifold ,think about it...
stren
vacuum or boost
just so that no one is confused the pipe i am talking about is a vacuum pipe from under the intake manifold to the breather there is a one way valve in the t piece so that when u boost the valve closes . so if the pipe is torn u loose vacuum on idle and boost when boosting
Nov 2, 2004
9,335
South Wales
Yeah its the PCV valve, you really need to log 118 to see what your WG duty is lookin like. If its jammed shut then your lookin at a boost/vac leak which would cause lean on off boost, but shoul in theory cause it to run rich.
Tom, you need to pop up and i'll have a look.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
118118 Logs Phil:
I cleared the fault and then did the logs, about 20 miles later fault is back. Grrr
BTW the external temp was about 30 degrees at the time, hence the high temps.
Code:
Wednesday	11	July	2007	13:47:35
6K0 906 032 AA 		1.8L 20VT EU3       0002
	Group A:	'118				Group B:	 Not Running
		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	°C	%	 mbar	STAMP
	0.53	3320	34	64.7	1640
	1.02	3480	34	71.8	1770
	1.53	3600	35	77.3	1920
	2.02	3800	36	76.5	1970
	2.53	3960	36	76.1	1960
	3.02	4080	36	75.3	1930
	3.64	4240	36	72.9	1870
	4.23	4400	37	72.5	1800
	4.73	4560	37	72.5	1780
	5.23	4680	37	72.5	1760
	5.73	4800	38	72.5	1750
	6.24	4920	39	72.9	1730
	6.73	5040	39	83.5	1800
	7.23	5160	39	80.4	1850
	7.73	5280	40	80.4	1810
	8.23	5400	41	78	1780
	8.73	4760	39	0	1310
	9.23	4120	39	0	1100
	9.74	4040	39	0	1050
	114.2	4560	33	0	1260
	114.91	4880	33	73.3	1330
	115.51	5320	34	73.7	1730
	116.08	4880	33	0	1350
	116.57	3600	33	58	1080
	117.08	3720	34	44.3	1480
	117.58	3840	34	44.7	1430
	118.08	3920	34	33.3	1420
	118.57	4000	33	23.5	1320
	119.09	4120	34	24.7	1350
	119.58	4200	34	29.8	1330
	120.08	4320	34	30.6	1350
	120.58	4400	34	26.7	1360
	121.08	4520	34	75.3	1380
	121.57	4680	36	77.6	1740
	122.08	4840	36	77.6	1820
	122.65	5000	37	78	1810
	123.39	5200	38	92.9	1880
	123.88	5320	39	85.9	1870
	124.37	5320	39	0	2270
	124.89	4160	37	76.1	1160
	125.37	4240	38	79.2	1790
	125.87	4320	39	77.3	1980
	126.37	4400	39	70.2	1830
	126.87	4440	39	57.6	1670
	127.37	4480	39	52.2	1500
	127.87	4360	39	1.2	1470
	128.37	4480	38	1.2	1320
	128.87	4520	39	81.2	1720
	129.38	4600	39	70.2	1840
	129.88	4640	40	61.6	1690
	130.49	4680	40	54.5	1550
	131.15	4640	39	0	1210
1,533
stupid question but a small thing or things that could have been overlooked
1 is the fuel cap sealing properly?
2 is the oil filler cap and dipstick guide sealing properly?
3 have you checked the earth points near the ecu to see if they are clean and corrosion free?
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
As far as i know the fuel cap should be sealing properly, is there a way of checking that?
Same for both the oil cap and dipstick aswell.
Aint checked the earth points near the ecu,, but i'll take a look at it,
Funnily enough, I read about the Ful cap earlier,
Cheers for the help mate, i appreciate iy.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
And no1 has just been replaced, so i hope its not that.
Cheers Goble, I havent touched the seal's but will try turning them around, and see if that helps.
Cheers again
Tom
Feb 25, 2007
657
stroud
i get catalyst efficncy below threshold bank one
ever since i put blueflame downpipe with hiflow sports cat ive changed lamba sensors but it still comes back
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Goble i checked the fuel cap and oil cap today and all seems ok, will try turning over the seal's tomoz.
Some logs from tonight, you may notice two sets in each log, which were done, before and after the fault was cleared. (The after ones are about 30min later, after giving the car a little drive)
Code:
Saturday	14	July	2007	21:30:37
	Group A:	'032
		Lambda	Lambda	Bin. Bits	Bin. Bits
	TIME
MARKER	STAMP	%	%
	0.72	2.3	25
	1.22	2.3	25
	1.72	2.3	25
	2.22	2.3	25
Saturday	14	July	2007	21:57:29
	Group A:	'032
	TIME
MARKER	STAMP	%	%
	0	0.2	2.3
	0.52	0.2	2.3
	1.08	0.2	2.3
	1.66	0.2	2.3
	2.19	0.2	2.3
	2.69	0.2	2.3
Code:
Saturday	14	July	2007	21:31:21
	Group A:	'033
		Lambda	Voltage	Bin. Bits	Bin. Bits
	TIME
MARKER	STAMP	%	 V
	0	-0.8	0.695
	0.62	-0.8	0.695
	1.15	-3.1	0.63
	1.65	-1.6	0.085
	2.15	0	0.09
	2.65	0.8	0.68
	3.15	0.8	0.71
	3.66	0.8	0.705
	4.15	-1.6	0.67
	4.65	-0.8	0.115
	5.15	0.8	0.065
	5.65	0	0
	6.16	0	0.86
	6.67	0	0
	7.15	0	0
	7.66	0	0
	8.22	0	0.8
	8.79	0	0.86
	9.34	0	0
	9.84	0	0
	10.35	0	0
	10.84	0	0.035
	11.34	0	0.07
	11.84	0	0.775
	12.34	0	0
	12.85	0	0.01
	13.35	0	0
	13.84	0	0
	14.34	0	0
	14.84	0	0.01
Saturday	14	July	2007	21:57:45
	Group A:	'033
	TIME
MARKER	STAMP	%	 V
	0	25	0.055
	0.58	25	0.05
	1.14	25	0.055
	1.69	25	0.05
	2.19	0	0.02
	2.7	0	0.025
	3.19	0	0.02
	3.69	0	0
	4.19	0	0.04
	4.7	0	0
	5.19	0	0
	5.7	1.6	0.055
	6.19	0	0
Now this seems odd, as the second clumn has changed, which i really dont understand!
Code:
Saturday	14	July	2007	21:31:59
	Group A:	'036
		Voltage	 	Bin. Bits
	TIME
MARKER	STAMP	 V
	0	0.155	Test ON
	0.5	0.16	Test ON
	1.05	0.175	Test ON
	1.67	0.085	Test ON
	2.21	0.005	Test ON
	2.7	0.05	Test ON
	3.2	0.06	Test ON
	3.72	0.055	Test ON
	4.21	0.525	Test ON
	4.71	0.375	Test ON
	5.22	0.01	Test ON
	5.8	0	Test ON
	6.3	0	Test ON
	6.8	0	Test ON
Saturday	14	July	2007	21:58:17
	Group A:	'036
		Voltage	 	Bin. Bits
	TIME
MARKER	STAMP	 V
	0	0.155	B1-S2 OK
	0.52	0.16	B1-S2 OK
	1.01	0.16	B1-S2 OK
	1.51	0.165	B1-S2 OK
	3.51	0.01	B1-S2 OK
	4.01	0.005	B1-S2 OK
	4.52	0.03	B1-S2 OK
	5.02	0.04	B1-S2 OK
	5.53	0.05	B1-S2 OK
	6.01	0.025	B1-S2 OK
	6.52	0.02	B1-S2 OK
	7.03	0.01	B1-S2 OK
	7.57	0	B1-S2 OK
	8.15	0	B1-S2 OK
	8.7	0	B1-S2 OK
	9.2	0	B1-S2 OK
And then a 002 after clearing the codes, and also letting the ecu adjust
Code:
Saturday	14	July	2007	21:43:17
	Group A:	'002
		RPM	Load	Inj. On Time	Mass Flow
	TIME
MARKER	STAMP	 /min	%	 ms	 g/s
	0	2640	112.8	10.66	61.89
	0.49	2720	124.8	11.07	68.94
	0.99	2880	135.3	11.89	76.64
	1.49	3000	141.4	13.12	83.11
	1.99	3160	140.6	13.12	85.11
	2.49	3320	153.4	14.76	100.81
	3	3480	159.4	15.58	108.92
	3.5	3680	155.6	15.17	109.58
	4.12	3840	153.4	15.17	110.81
	4.66	4080	153.4	15.17	120.44
	5.2	4280	150.4	14.76	121.44
	5.7	4440	147.4	14.35	126.69
	6.2	4600	145.9	14.35	128.56
	6.71	4800	142.9	13.53	130
	7.2	4720	41.4	1.23	0
	7.7	3960	15	1.23	10.17
	8.2	3280	9.8	0	5.53
	8.7	3760	86.5	7.79	71.17
	9.2	3760	136.1	11.89	109.72
	9.7	3880	161.7	15.99	117.97
	10.19	3960	158.6	15.58	121.44
	10.68	4080	157.1	15.58	122.33
	11.19	4200	150.4	14.76	119.78
	11.76	4280	147.4	14.35	120.08
	12.42	3800	13.5	1.23	4.64
	12.98	3040	12	0	4.53
	13.48	3400	5.3	0	3.5
	13.99	3320	6.8	0	4.53
	14.49	3240	7.5	0	4.78
	15	3200	8.3	0	4.92
	15.48	3120	8.3	0	5.03
	15.98	3040	8.3	0	4.94
	16.48	3000	8.3	0	5.03
	16.98	2960	8.3	0	4.81
	17.48	2920	8.3	0	4.75
	18	2880	8.3	0	4.67
	57.96	1640	96.2	8.61	31.22
	58.47	1720	97.7	8.61	32.11
	58.96	1680	100	9.02	33.83
	59.51	1800	100	9.02	34.08
	60.2	1840	102.3	9.02	37.97
	60.76	1920	104.5	9.43	40.61
	61.27	2000	108.3	9.84	43.17
	61.76	2080	111.3	9.84	46.5
	62.26	2160	114.3	10.25	48.17
	62.78	2240	118.8	10.25	52.75
	63.27	2320	124.8	11.07	58.14
	63.76	2400	132.3	11.48	63.06
	64.26	2480	142.1	13.12	70.72
	64.76	2600	150.4	14.76	77.5
	65.26	2760	153.4	14.76	82.14
	65.76	2920	154.9	15.17	85.94
	66.26	3040	154.9	15.17	90.25
	66.78	3200	154.9	15.17	93.42
	67.27	3360	154.9	15.17	101.11
	67.84	3520	154.1	14.76	104.22
	68.43	3680	151.9	14.76	106.86
	68.96	3880	149.6	14.76	111.86
	69.46	4000	148.9	14.76	113.94
	69.96	4120	147.4	14.35	116.58
	70.46	4280	145.1	14.35	118.89
	70.96	4400	143.6	13.94	120.75
	71.45	4520	143.6	13.94	127.61
	71.97	4640	157.9	16.4	142.19
	72.47	4800	157.9	15.99	145.44
	72.96	4920	156.4	15.58	146.53
	73.46	5040	154.1	15.58	148.47
	73.96	5200	151.1	15.58	151.17
	74.46	5240	148.9	14.76	152.69
	74.96	5360	147.4	14.76	151.92
	75.55	5480	144.4	14.76	151.5
	76.13	5560	141.4	13.94	149.72
	76.66	4520	19.5	2.46	20.61
	77.16	4280	133.1	11.48	124.28
	77.66	4640	158.6	16.4	144.22
	78.16	4280	68.4	3.69	19
	78.66	4000	13.5	1.23	7.11
	79.17	3360	9.8	1.23	8.64
	79.66	2680	6	0	2.67
	80.15	2040	6.8	0	2.47
	80.65	1400	8.3	1.23	2.69
	81.16	1040	18.8	2.05	6.33
	81.65	1080	14.3	1.23	2.22
	82.15	1400	8.3	1.23	2.06
	111.65	3440	154.9	15.17	104.42
	112.14	3640	154.1	15.17	106.53
	112.63	3800	152.6	15.17	110.42
	113.13	3960	154.1	15.17	116.89
	113.64	4160	151.9	15.17	120.67
	114.13	4280	149.6	15.17	121.89
	114.64	4440	159.4	16.81	137.89
	115.17	4640	160.2	16.81	142.22
	115.72	4760	157.9	16.4	141.33
	116.33	4920	156.4	16.4	148.86
	116.84	5120	152.6	15.99	149.97
	117.34	5240	149.6	15.17	150.72
	117.84	5360	146.6	14.76	150.17
	118.34	5440	144.4	14.35	149.64
	118.85	5560	139.8	13.12	148.42
	119.34	5440	141.4	13.12	150.92
	119.84	4560	46.6	8.61	59.83
	120.34	4400	142.1	12.71	133
	120.84	4480	157.9	15.58	135.69
	121.34	4560	153.4	15.17	131.28
	121.84	4640	150.4	14.76	132.44
	122.34	4680	148.9	14.76	133.44
	122.84	4760	148.9	14.76	134.31
	123.41	4800	148.9	14.76	137.03
	124.02	4880	147.4	14.35	136.47
	124.54	4960	145.9	14.35	137.22
	125.06	5000	144.4	13.94	137.22
	125.54	5040	142.9	13.53	136.83
	126.04	5080	142.9	13.94	140.06
	126.56	5120	142.9	13.94	139.86
	127.05	5200	139.8	13.12	137.22
	127.54	5240	139.8	13.12	139.97
	128.04	5280	142.9	13.53	145.47
	128.55	5320	146.6	15.17	150.08
	129.05	5360	147.4	14.76	151.39
	129.55	5400	145.9	15.17	149.81
	130.03	5200	36.1	1.23	0
	130.53	4360	60.2	8.2	79.03
	131.07	4320	139.8	11.89	127.81
	131.74	4360	157.1	15.58	131.81
	132.27	4400	155.6	15.58	130.33
	132.82	4440	154.1	15.17	130.22
	133.33	4480	154.9	15.17	131.97
	133.83	4480	153.4	15.17	131.03
	134.32	4520	149.6	14.76	128.17
	134.83	4560	148.1	14.76	127.11
	135.33	4480	24.1	1.23	13.67
	135.83	4400	9	0	6.86
	136.32	4360	5.3	0	4.69
	136.83	4280	6.8	0	5.75
	137.33	4240	7.5	0	6.47
	137.83	4160	7.5	0	6.83
	138.32	4120	8.3	0	6.86
**** Phil, i have noticed i am getting a Low Fuel fault code aswell now.
While checking today, i noticed the brake servo pipe has split again, so that will be going back in, as it had already been replaced. Fingers crossed its just that, although i'm sure that was ok last time i checked .
