Rich!!can you call me Rich, thanks
changed you name Bill??
Or just won the lottery?
sorry cheap one, lol
Rich!!
The disc retaining bolt can be a bastid, I have used a cold chisel before, order new ones to be sure.
you'll need new calliper bolts for the front as you need to remove these to change discs and there one use.
Make sure you have a big assed bar as they should be tight as. the nipples for bleeding the Brembo's are 11mm which is an unusual size.
Rich!!
i just used loctite instead of new calliper bolts, also there is a tool that can buy to remove the screws if cant getit out with a chizel, its a kind of impact driver kind of thing. are new bolts really necessary willie as ive changed brakes an past an sed loctite an been fine.
I hoped not as I just sent off a spare set to another member! Thanks for clearing that up...caliper bolts are'nt one time use.
they're not stretch bolts.
I've found the serrated washer teeth get crushed on torquing once so not willing to take the risk with such an integral partcaliper bolts are'nt one time use.
Rich, don't worry about the chisel. It's not an essential tool for this job.
Change bolts as Bill has suggested
