still confused as to how it must be one but not etc byt never mind - only ever read the drag racing bits normally anyway
so when you paying up then ?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
This discussion is over and you need to carefully consider what you are saying. All you have said is noted.
If you wish to take this further, you need to put your money where your mouth is and make an official protest to the MSA.
Its put up or shut up time.
As above, if you're going to withhold information and put up silly pictures, it's apparent you can't or won't be transparent about your engine identity.Openess by Rob as to his block would clear up this argument and show that he is within the rules
Openess by Rob as to his block would clear up this argument and show that he is within the rules, although I do see that he is having fun taking Chris for a little goose chase.. 1.8 ADL bored to 2.0 would sit him perfectly well within the rules would it not?
go more all out with the ibiza
Uhuh..... because a wide arch 9000rpm revving car isn't "enough" all out?
